Hello Guest it is November 13, 2026, 07:43:25 PM
Author Topic: Sherline Rotary Table NC control  (Read 11898 times)
« on: April 10, 2011, 04:52:01 AM »
I live in New Zealand and am new to the Forum. I have a Taig CNC mill to which I have just added a Sherline rotary table. It is all hooked up and running fine, set up for A axis operation. My question is; can Mach3 continuously rotate the rotary table?
Thanks in advance,
Ken.
Re: Sherline Rotary Table NC control
« Reply #1 on: April 10, 2011, 06:17:32 AM »
If you are trying to use it as a spindle then no not really. There may be ways to accomplish this but nothing as simple as just commanding an A axis continuous rotation.
« Reply #2 on: April 10, 2011, 07:29:28 AM »
In addition to what Hood posted, you will want to use a servo and not a stepper for turning it continously.
Offline Mc2
  •  31 31
« Reply #3 on: April 13, 2011, 07:26:27 AM »
Thanks in advance,
Ken.
Not sure why you would want to but, if you set up your A axis as a spindle then you could. You would have to turn on spindle with M03 or M04 with a speed command. You may only get 4 or 5 rpm out of it though. This would be hard on the table over time. On the other hand, you could command the A axis for a position in multiples of 360. Say you wanted to rotate twice. The command "G01 A 720 F 500" even with the rollover it should rotate twice around.
Jim.
