Hello Guest it is November 13, 2026, 06:11:38 PM
Author Topic: 1980 Mori Seiki SL1 CNC Lathe to Mach3 Conversion  (Read 118176 times)
Offline dresda
  •  220 220
Re: 1980 Mori Seiki SL1 CNC Lathe to Mach3 Conversion
« Reply #10 on: April 14, 2011, 02:17:03 PM »
What is YAPSC?
« Reply #11 on: April 14, 2011, 02:23:23 PM »
Its a step/dir to analogue converter. You connect it to the Step/Dir from Mach and your encoders go to the YAPSC and then it will output the +-10v for your analogue amps.
Not 100% sure but think it comes in kit form, do a search on the CNC Zone and you should find info.
« Reply #12 on: April 14, 2011, 05:09:38 PM »
drives would be +-10volts analogue so you would need a $1000.00 motion board
you can use YAPSC for this purpose. Cheap and reliable
Dear JH
is it possible ask about price for lathe ?
Approximate price What is it?
Amir
Not sure about YAPSC Products....  My guess its like a Pixie P100
The lathe as is cost $2500 USD, plus shipping and Mach3 Mods ...
JH
Spindle Driver VFD
« Reply #13 on: April 15, 2011, 01:47:10 PM »
I was able to find the Yaskawa AC Spindle Drive Documentation / Specs for the CIMR-MT7.5K.  The thing with most of these Spindle Drives are that they are 3 phase ( or are they…. )   The only thing that is 3 phase is the 6 diode bridge rectifier that converts the AC into DC for the internals of the unit to then recreate the 3 Phase AC for motor with adjustable frequency to control the speed.  If you connect single phase to the rectifier, then you are only using 4 of the diodes to generate the internal DC, this means you can use single phase on the AC Spindle Drive.  (this is my theory, I have not tried it)
My plan is to remove it and replace it with a NEW Drive that supports ModBus for the control and interface to Mach3
« Reply #14 on: April 19, 2011, 02:50:47 PM »
Well….  I messed up.  My spindle is the CDMR-MR 7.5K not the CIMR-MT 7.5K, this means its not an AC Motor, it’s a monster DC motor.  This changes my entire plan, so for now, I will just break down the machine to the components that I plan on keeping for now….
« Reply #15 on: April 19, 2011, 03:02:16 PM »
Here are some pics of the tear down....
« Reply #16 on: April 19, 2011, 03:03:02 PM »
and a couple more ...
JH
Offline cnc-it
  •  153 153
« Reply #17 on: April 25, 2011, 01:52:10 PM »
Some nice gear there JH. All these motors and drives can be run from a Galil motion card. The Galil cards need an encoder feedback and I'm thinking with those drives you have might have a Tach feed to them from the motherboard to regulate the speed.
The encoders will probably go to the motherboard which handles the positioning and also creates a tach signal for the drives from the encoder feed?
Presume you are loosing the drives though as they are 3 phase...just pointing out if your motors don't have Tachos it might be a pia!
Looks like a Fanuc 5T control to me or maybe a Fanuc 6A?
The Fanuc AC analogue drives A06B-6050 types commutate the motor from the drive using the encoder position which is set to a certain angle with the motor poles. The encoder feed also goes to the Fanuc mother board which closes the position loop and handles the motion commands to give the drives the analogue signal they require.
On the Fanuc DC Yellow cap motor set up (similar to the Yasanak) the mother board converted the encoder signal to a velocity signal for the drives and also used it to close the loop..no tacho needed on the motors..works very well!
john
« Last Edit: April 25, 2011, 01:56:10 PM by cnc-it »
Offline dresda
  •  220 220
« Reply #18 on: April 25, 2011, 09:04:10 PM »
I would be looking at Galil or somebody else, I am still trying to get my DSPMC to work on red cap Fanuc, and on my other project with DC servo Dynamics the DSPMC works but the Acc/Dec in feed hold is pathetic @ .75ms. I have been asking for him to change it to 150ms or whatever for months. Also, I bought a really nice USB hand held pendant from Andrey in Russia, doesn't work, conflict with DSPMC plug-in.
Ray.
« Reply #19 on: February 04, 2013, 01:28:31 PM »
Does anyone know where I can get the manuals/connection diagrams for the Z and X axis servo drives?  This is on a Mori Seiki SL-3 with Servopack CPCR-MR 052 GB and CPCR-MR 152 GC drives.  I am getting ready to do a retrofit to Mach3 with a Galil motion controller and a DL06 PLC.
Also if anyone knows where I can get the wiring schematics for this Lathe that would be a great help too.
