Hello Guest it is October 20, 2026, 09:59:52 PM
Author Topic: Outline and pocketing  (Read 10714 times)
« on: April 05, 2011, 02:39:21 PM »
Hi everybody,
For days and days i study all the mach3 manuals in order to find out how to compensate mill diameter for outline milling (or pocket).I have a complex outline shape and i want a exact outline.I tried it allso with CAMBAM ,but somehow i am getting lost.
Maybe someone can give me some advise?
Sam
Re: Outline and pocketing
« Reply #1 on: April 05, 2011, 03:56:50 PM »
Post the dxf file.
Also define how deep and what size end mill you will be using.
If using Lazycam then you need a Pro license to do offsets.
  •  9,374 9,374
« Reply #2 on: April 06, 2011, 03:42:08 AM »
Sam,
I have used the free version of CamBam for some time now, it has it's quirks but I think it does make an excellent job of applying tool radius compensation to the generated GCode. Perhaps a bit more practice with the software  ;)
Alternately why not read up the Mach manuals etc. on tool radius compensation and using G40 / G41 / G42 in your GCode.
« Reply #3 on: April 06, 2011, 04:31:28 AM »
Thank you guys, i am gonna test and practice. In CAMBAM i thought i did implement the tool diameter but i must do something wrong. I will look in mach3 for these G40,41 and 42 codes .
Sam :)
