Hello Guest it is October 21, 2026, 08:28:14 AM
Author Topic: copycat, cutting an arc in the xz plane  (Read 21095 times)
« on: April 04, 2011, 07:52:16 AM »
Sorry it's probably just me, but I can't find a manual for copycat, I want to be able to cut an arc in the xz plane, using copycat, it just doesn't  want to do it, I am picking a start, middle and end point, but instead of describing a concave arc on the xz plane,it starts at the start point, and then the z axis rises, until by the time x reaches it's end point it is about an inch above where it should be, it works as a "v" if tell it to go in straight line moves, why not an arc?
Mike
Re: copycat, cutting an arc in the xz plane
« Reply #1 on: April 04, 2011, 11:05:57 AM »
Mike,
There is a manual for Copycat in MEMBERS DOC's.
No other information exists other than what is in the manual.
If it's not in there, well, i guess......your on your own.
BTW, You need a NFS license to post code from it if I remember correctly.
« Last Edit: April 04, 2011, 11:07:31 AM by RICH »
« Reply #2 on: April 04, 2011, 01:10:56 PM »
Had what I thought was a brainwave, and lowered z axis 0.0 point to below the lowest point in the arc, so that it stayed in positive numbers because the error message said it couldn't divide by zero, but it hasn't made any difference, anyone else had this problem, and worked out a workaround?
cheers
mike
« Reply #3 on: April 04, 2011, 02:48:24 PM »
It appears the Copy Cat does not allow arcs ouside of the G17 plane(XY) even thought it will produce a spiral (;-)
« Reply #4 on: April 04, 2011, 03:14:34 PM »
I don't understand that, I can't be the only person who wants to cut a dish shaped profile, what is the difference between xy and xz movements? is this a bug in the software?
cheers
mike
« Reply #5 on: April 04, 2011, 03:53:25 PM »
Hi Mike,
  I'd say that it's not the software (Mach) or a bug, but rather a limitation of the Wizard.
When you hit the "New Teach File" button you can see G17 planted in the preamble.
Ron Ginger might share some insight on the subject as he is the Wizard Master.
Russ
« Reply #6 on: April 04, 2011, 04:17:28 PM »
Mike,
There are some basic differences. The ZX ( G18 ) defines a different plane of reference for the arc motion as to what is cw or ccw ( GO2 / G033 ) and uses IK instead of IJ. So to get the arc motion correct the G18 plane is called out in the code, and if not,  ie; I& J are used in G17 you will get an error. Now something you may want to try is just use the Y axis instead of the Z axis ( swap cables ) or for that matter manipulate the produced Gcode.
BTW, Your the first person to post something on CopyCat in a long time. If you have a camera and an XBox  you can do some neat stuff for tracing out patterns and generating gcode for them. Now I know there is more than one user........ ;)
Have fun,
« Reply #7 on: April 04, 2011, 04:56:33 PM »
got a camera, but no xbox, I was thinking of rigging up a couple of laser pointers to locate the place where the beams coincide "a la dam busters" what is the story with the xbox? won't a computer do?
« Reply #8 on: April 04, 2011, 04:56:41 PM »
You will also find that mach cannot do an arc in the G19/19 planes IF it is offset from the parent plane in a radial fashion. Such as cutting a bowl using only G17 arcs and rotating around the centerpoint with the arcs to form the bowl.  It would require a 3rd operator to define the arc through the 3 planes at the same time.
But that is just the way it has always been, so nothing new. You just have to learn to work around it.
« Reply #9 on: April 04, 2011, 05:09:58 PM »
I'll try the trick with swopping the leads, let you know how it works out
