Hello Guest it is October 02, 2026, 08:07:53 AM
Author Topic: Changing the number of decimal points machine works to  (Read 8781 times)
« on: April 04, 2011, 01:03:54 AM »
Hello all.
Im not sure if i have posted this in the right section hope i have, anyway i have a sieg lathe that is running mach 3, it is set to millimeters and at the moment the machine is machining to 4 decimal places.
how do i change it to 2 or three, accuracy isnt a real issue, im just having a couple of glitches with he wizards trying to match arcs with so many decimal places
thanx in advance for your help
regards
Grant
Re: Changing the number of decimal points machine works to
« Reply #1 on: April 04, 2011, 06:16:55 AM »
You need to edit the format of the DRO's in a screen designer. You'll need to edit each one individually.
However, I believe that this will only change what is displayed. Internally, Mach3 will still use much higher precision.
