Hello Guest it is October 20, 2026, 05:04:25 PM
Author Topic: reset servodrives with mach3  (Read 9086 times)
« on: April 01, 2011, 03:37:04 PM »
Hello, i am new here. I am retrofitting a Aciera f35 milling machine with mach3 and Granite. At this moment everything works fine and i made my first parts, but i have the following question:
Does anybody know how i can reset my servodrives (Granite VSD-XE with VSDEPI) in the mach3 programm? If i have a blocked servo due a failure mach3 stops all my drives (E-stop), but i have to reset my drives first in order to be able to reset in mach3.
Re: reset servodrives with mach3
« Reply #1 on: April 01, 2011, 04:19:28 PM »
Not 100% sure what you are asking but if its just a signal from Mach that you are needing then as long as you have a spare output you could make up a screen button to reset the drives if they fault.
« Reply #2 on: April 02, 2011, 12:35:30 AM »
Thank you Hood, I am gonna trie that!
