Hello Guest it is October 20, 2026, 07:52:52 PM
Author Topic: cutter compensation not working  (Read 13362 times)
« on: April 01, 2011, 11:33:53 AM »
having trouble with mach3 with cutter comp taking affect,i am using tool 1 with cutter radius in tool table (R.187 IN TOOL DIAMETER)
on the main screen shows tool 1 and shows cutter radius but when running program tool goes to center line of cutter
and does not compensate for tool radius.
example program milling inside pocket
G17 G20 G40 G80 G90
T1M6(.375 endmill)
G0 G90 G54 X2.0 Y2.0 G43 H1 Z-1.0 S3000 M3
Z.1
G1 Z-1.25 F30.
G42 D31 Y2.5
X2.5
Y1.5
X1.5
Y2.5
X2.3
G40 Y2.0
G0 Z1.0
G53 Z0
M30
Re: cutter compensation not working
« Reply #1 on: April 01, 2011, 04:26:41 PM »
The D parameter should reflect the tool number.
Try D1
Jeff
« Reply #2 on: April 01, 2011, 06:29:14 PM »
jeff
i just tried and it worked fine
i guess i just had d32 stuck in my head from the fanuc controls
at work .
thanks very much for response
« Reply #3 on: April 01, 2011, 07:13:38 PM »
D is the tool # who'd diameter you're using for the comp.
