Hello Guest it is October 22, 2026, 05:06:18 PM
Author Topic: 4th axis setup  (Read 95272 times)
Re: 4th axis setup
« Reply #60 on: April 29, 2012, 11:24:58 AM »
Hello!
It´s not possible to change the standard output from RC.
All i can change in RC PP is adjust the increment rotation in relation to the standard rotation.
The negative output of A i can´t change. I told you this is fixed writen by program.
Also i can´t change the displayed standart direction of Mach.
So it seems i have to live / accept the displayed reverse Toolpath.
The Axis rotate in Match to RC now.
Maybe Greolt have some idea.
BR Rudi
Re: 4th axis setup
« Reply #61 on: April 29, 2012, 11:36:27 AM »
MOst Cams you can change the output code to suite youself through the POST processor.
