Hello
Guest
it is
November 01, 2026, 10:10:48 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
LazyCam (Beta)
Circles
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Circles (Read 13886 times)
kolias
1,165
Circles
on:
March 26, 2011, 01:54:46 PM »
Iām experimenting with LC and made in Acad V.14 a circle 1-1/16ā OD
I import the dxf file to LC, selected a 1/4" bit and got the g-code on Mach
When the cut was done, the circle OD was 1.29ā
Am I doing something wrong?
Logged
Nicolas
Re: Circles
Reply #1 on:
March 27, 2011, 06:31:02 AM »
If you just selected that circle in LC and didn't do any offsets then the pathing would be along that circle and the od cut would be
1.3125". Now if it only cut 1.29", then you could have done something wrong in LC or you have someting set wrong in Mach.
Logged
ger21
6,295
Re: Circles
Reply #2 on:
March 27, 2011, 09:07:40 AM »
In AutoCAD, you need to make the circle 1-1/16 minus the tool diameter, or 13/16". Normally, the lines and circles you draw in AutoCAD are the center of the tool, unless you use offsets in your code, or let your CAM program do the offsets.
Logged
kolias
1,165
Re: Circles
Reply #3 on:
March 27, 2011, 10:11:11 AM »
1.3125 is my circle OD + the tool diameter so as Gerry is saying I will redraw the circle minus the tool diameter
Good to know this, thank you both
Logged
Nicolas
ger21
6,295
Re: Circles
Reply #4 on:
March 27, 2011, 10:41:38 AM »
So in your original question, are you asking why it's 1.29 instead of 1.3125?
Logged
kolias
1,165
Re: Circles
Reply #5 on:
March 27, 2011, 11:23:53 AM »
In my original question the 1.29" was wrong (I didn't measure correctly). I check it again and it is 1.3125"
I try to press fit a bearing with an OD of 1-1/8" and I'm experimenting that 1st on MDF and after it will be done in Aluminum
I just cut 3 circles, 13/16", 14/16" and 15/16". The bearing fitted just tight, as I wanted on the 14/16" circle
Of course in the Aluminum it may be different but I will experiment and see the results
Logged
Nicolas
Re: Circles
Reply #6 on:
March 27, 2011, 12:06:05 PM »
Nicolas,
Think the numbers in reply #5 are somewhat mixed up.
Logged
kolias
1,165
Re: Circles
Reply #7 on:
March 27, 2011, 01:07:31 PM »
Sorry RICH, the numbers on reply #5 refer to the circles I made in ACAD minus the 1/4" tool diameter.
So the 13/16" circle has a 1.0625" OD
the 14/16" circle has a 1.125" OD
the 15/16" circle has a 1.18" OD
Logged
Nicolas
Print
Pages:
1
Go Up
« previous
next »
