Hello Guest it is November 13, 2026, 06:23:08 PM
Author Topic: Pokeys analog input & Feed Rate DRO  (Read 41499 times)
Re: Pokeys analog input & Feed Rate DRO
« Reply #10 on: September 04, 2014, 05:13:54 PM »
when you use the current plugin you doent need a brain. Easy to setup.
Whitch kind of Pokeys do you use? 55 or 56 ?
Alex
« Reply #11 on: September 04, 2014, 05:42:18 PM »
I use the 56U model
I've set the analog input in the config of mach3 and set the gain at 300% and it work well, but I have the same problem of led red blinking when I try to set it at 100%.
I've read about this brain to reset the feed override to 100% when the value is between 98% and 102% but it don't work.
What I can do?
« Reply #12 on: September 05, 2014, 02:30:30 AM »
Forget about the brain and under Mach3 go to Plugin control -> Pokeys Plugin.
Play with the Gain and the DROs you want (DRO 3 and 821 i think).
On your hardware make a jumper between 2 analog inputs. So you will map one input at DRO 3 and one at 821.
I hope it helps...
Giannis
« Reply #13 on: September 05, 2014, 04:58:43 AM »
why i need 2 analog inputs?
I have read here about a brain to set 100% when the control is between 98 and 102
« Reply #14 on: September 05, 2014, 09:22:02 PM »
I tried to get it with a brain with no success. Look like it will not work with a brain.
Anyway, it will using the macropump.
No guarantee at all and at your own risk!
Map the analog input to a userdro instead of dro 821 ( FRO)
I used DRO1998.
check " use macropump " in general config.
content of macropump:
a = GetOemDro(1998)
If GetOemDro(1998) < 97 Or GetOemDro(1998) > 103 then
SetOemDro(821,a)
else
SetOemDro(821,100)
End If
If GetOemDro(1998) < 3  then
SetOemDro(821,0)
End If
End
Alex
« Reply #15 on: September 05, 2014, 10:53:51 PM »
looks like this brain is working.  ;D
Alex
