Hello Guest it is November 22, 2026, 03:19:22 PM
Author Topic: Shuttle RU pendant help  (Read 10512 times)
Offline dresda
  •  220 220
« on: March 24, 2011, 08:33:23 PM »
Does anybody have the Shuttle RU pendant from Andrey in Russia. I just bought one and it works except for the outer ring, it doesn't do anything, I think it is for the slow/fast jog. I am having a few problems with the language barrier between Andrey and myself.
I set up the the buttons on the plug in screen and they all work, Andrey said I don't have to setup the wheels but I was wondering if i have to set anything in the Mach3.
Ray.
P.S. I bought two pendants and they both do the same thing.
Offline rasta
  •  32 32
Re: Shuttle RU pendant help
« Reply #1 on: February 05, 2020, 02:40:26 AM »
Hi;
I have the opposite , when I turn the ring it wont stop , unless I press the ESC key on the keyboard, I think that your problem is on the setting on the MPG
press the TAB, key in the Keyboard , and play with the settings on the MPG that pops out
regards
Mariano
« Reply #2 on: February 22, 2020, 01:12:45 PM »
Hi Rasta, I had the same problem and discovered that this happened when fast jogging with the outer ring and accidentally turn the fine positioning jog knob.
Regards marting
