Hello Guest it is November 22, 2026, 02:27:46 PM
Author Topic: Mach 3 - CNC always stopped at the line 500  (Read 30923 times)
« on: March 23, 2011, 07:38:17 PM »
Hi fox,
I'm using Solidworks - MasterCam X3 - Mach 3 to engrave a text by my CNC hobby machine. Drawing, G-code generating and tool path verified are well obtained. I tried to run the program on my CNC machine. It started to cut very well. However, the program crashed at the line 500. After restarted the computer and tried to RUN FROM HERE at line 480. It stopped again at 500. It happended the same with other programs. Is there any setting need to be changed? How to solve the problem ?
Your advice is really appreciated.
Austin
Re: Mach 3 - CNC always stopped at the line 500
« Reply #1 on: March 23, 2011, 07:45:55 PM »
That's a limitation of the DEMO version.
You need to purchase a license to go further.
Unless you have one and do not have it in the Mach3 folder?
Russ
« Reply #2 on: March 23, 2011, 07:48:04 PM »
I forgot to attach the sample .NC file in case you need
Here below:
« Reply #3 on: March 23, 2011, 07:49:27 PM »
I'm using the licensed version
« Reply #4 on: March 23, 2011, 07:53:47 PM »
If you go to Help > About, is your name in the window that opens? If not, your license is not working.
« Reply #5 on: March 23, 2011, 07:55:47 PM »
So, in the upper lefthand corner of your screen, it says "Mach3 CNC Licensed to: YOU" ?
If so, is there an error message when it stops ?
« Reply #6 on: March 23, 2011, 07:57:40 PM »
You may have purchased a license but have it in the wrong place.
Or like Ger said ... it might be broke.
Just coincidental that it stops at the demo limit.
« Reply #7 on: March 23, 2011, 08:21:20 PM »
ON the help > About i see the licence is granted to Fabalo ff.
On the upper left also saying the licence is granted to Fabalo ff.
This one i got it from a friend. I didn't purchased.
There was no error message when problem occurred. It just all stoped. stepper motors were freeze
« Reply #8 on: March 23, 2011, 08:25:21 PM »
Contact Andrew or Scott at Mach Support. That license evidently has issues.
« Reply #9 on: March 23, 2011, 08:47:28 PM »
Thanks all. I'll contact my friend
