Hello Guest it is November 22, 2026, 02:24:21 PM
Author Topic: Mach3 - G code loading problem  (Read 23937 times)
« on: March 20, 2011, 10:47:59 PM »
Hi mentors,
I need some help with my current problem loading G-code into Mach3.
I drawn a part by Solidworks 2010, then used MasterCam X3 to generate G-code. I used pocket feature (from tool path) on the drawing part. It successfully verified the toolpath from MasterCam and generated G-code saved as .NC file.
I uploaded the .NC file into Mach3 to run the program on my Hobby CNC. The toolpath on Mach3 just showed an empty block. I don't know why. I previously could generate the simple program with a rectangular and drill couple holes. But it didn't work with the more complicated program.
Your help is greatly appreciated.
rainnyday
  •  9,378 9,378
Re: Mach3 - G code loading problem
« Reply #1 on: March 21, 2011, 02:47:31 AM »
Do you get an error message in the status bar at the bottom of the screen ?
« Reply #2 on: March 21, 2011, 04:26:39 AM »
Also, what post do you use, Fanuc work great with mach3.
Do you see Gcode on the left side of the screen.
Jeff
« Reply #3 on: March 21, 2011, 03:23:49 PM »
I'm not using MACH3 with Fanuc machine. I'm using it for my hobby CNC.
The Gcode window is appeared on the left as normal and there is no error code.
Thanks.
« Reply #4 on: March 21, 2011, 03:44:04 PM »
Then post your code so we can see why it doesn't work.
« Reply #5 on: March 21, 2011, 03:53:47 PM »
Hi Ger21,
This is the code file. I used open pocket milling. It is long.
« Reply #6 on: March 21, 2011, 04:00:27 PM »
There's an error message about using two g-codes on the same line. Here:
N8006 G91 G0 G28 Z0.
and Here:
N8006 G0 G28 Z0.
Change those two lines to this, and it works fine.
N8005 G91
N8006 G0
N8007 G28 Z0.
« Reply #7 on: March 21, 2011, 04:02:41 PM »
Thanks.
Fanuc was not about machine, it was about a Fanuc Post inside Mastercam
Jeff
« Reply #8 on: March 21, 2011, 04:02:51 PM »
I screwed that up. Change this line:
To
N8006 G91 G0
N8007 G28 Z0.
