Hello Guest it is November 08, 2026, 02:37:29 AM
Author Topic: X AXIS STOPS APROX .500 SHORT OF HOME SWITCH  (Read 11104 times)
« on: March 17, 2011, 01:34:18 PM »
using mach3
 y and z axis work fine they hit home switch and back off switch a small amount every time
i tried wires from y and z same problem
any ideas
Re: X AXIS STOPS APROX .500 SHORT OF HOME SWITCH
« Reply #1 on: March 17, 2011, 03:21:18 PM »
If you attach your xml I will see if I can find a config problem. Do you get a reset when this happens?
Re: X AXIS HOME SWITCH TRIPS EMERGENCY STOP
« Reply #2 on: March 18, 2011, 01:15:32 PM »
i fixed that problem the active low on x++ was on i turned it off and now it goes to home switch and stops but does not back off switch and it trips emergency stop
i checked the diagnostics and when tripping switch the home and x++ light up yellow but also shows emergency stop in red
y and z do not show emergency stop
« Reply #3 on: March 18, 2011, 05:34:22 PM »
Sounds like your switch may not be a positive action and it is bouncing thus Mach thinks it has backed off and then its seen again and by this time its seen as a limit because homing has finished. To see if this is the case if you home and see the the X DRO zero (machine coords) then that is the problem. Setting a debounce interval may help hide the problem.
« Reply #4 on: March 23, 2011, 01:12:03 PM »
i tried that and it did not go to zero i ended up moving wire from input 1 to input 4 on mach3 breakout board  and it now works ok.
thanks for input
