Hello Guest it is October 16, 2026, 03:53:38 AM
Author Topic: Machining Damascus Steel Questions  (Read 16093 times)
« on: March 17, 2011, 12:13:08 AM »
Anything special I should know about working with Damascus steel before I ruin a ton of endmills making parts? Also, does anyone know of a good site to order large pieces of Damascus?
Offline kf2qd
  •  157 157
Re: Machining Damascus Steel Questions
« Reply #1 on: March 17, 2011, 08:01:05 AM »
Never machined it, but due to the nature of the way it is made (heating and forge welding, some carburizing of the layers) I would expect that you would encounter problems with hard & soft spots. All the damascus steel I have seen was manufactured by the blacksmith making the product. Good luck on finding blocks of the stuff...
« Reply #2 on: March 17, 2011, 11:49:02 PM »
Stonerarms, I don't know if it's a good site, but you might check out http://www.ancientarms.biz/servlet/StoreFront
Googling damascus billet should find more
Randy
« Last Edit: March 17, 2011, 11:50:37 PM by zephyr9900 »
Offline Fredzway
  •  8 8
  • I don't suffer from insanity, I enjoy every minute
« Reply #3 on: March 18, 2011, 09:00:32 AM »
Just to share a little knowledge and opinion. Damascus steel conjures images of Elmer Fudd and Bugs Bunny ( the exploded gun barrel, Mythbusters never did get it right). By design Damascus is very hard in spots and softish/flexible in others. Originally forged to shape then polished and honed with abrasives. Wet grinding might work better than cutting. If it is not revealing too much what is your goal?
Fred
I am an old man and have known a great many troubles, most of them never happened. - Mark Twain
« Reply #4 on: March 18, 2011, 07:40:24 PM »
Fred
Mostly just custom parts, nothing with any pressure exerted upon it.
Offline Fredzway
  •  8 8
« Reply #5 on: March 18, 2011, 08:17:50 PM »
Damascus steel looks like strands of cable. In a gun barrel it was twisted around a mandrel and blacksmith welded. Is it the Look of it you are after or just the legendary properties?
Fred
« Reply #6 on: March 18, 2011, 08:19:55 PM »
Fred
Mostly just the look. I am not trying to make barrels out of it, just small parts.
