Hello Guest it is October 17, 2026, 04:26:06 PM
Author Topic: need help with simple brain  (Read 7240 times)
« on: March 15, 2011, 05:17:13 PM »
I have (1) input to my mach that I want to use if it goes high the (feedhold) goes on
or if it switches back to low the program automatically resumes.
Anyone know how to do this?
Re: need help with simple brain
« Reply #1 on: March 16, 2011, 08:41:23 AM »
Pretty simple to do, but I wouldn't as it wouldn't be safe.
Any time the input went OFF, the cycle would start, maybe not when you wanted it to.
You could use your input to an OEM trigger to feedhold, then require a Cycle Start to resume as normal.
Just doesn't look safe to me to do what you are asking.
Perhaps a more complex Brain could be safer than mine. ;D
Most likely the case. :)
Russ
