Hello Guest it is November 01, 2026, 12:19:57 PM
Author Topic: Posting gCode  (Read 28028 times)
Offline kolias
  •  1,165 1,165
Re: Posting gCode
« Reply #10 on: March 15, 2011, 05:56:49 PM »
Thank you both
Gerry I think I will install the "memoryoverride.reg" file and see the results
I will post back
Nicolas
Re: Posting gCode
« Reply #11 on: March 15, 2011, 06:01:45 PM »
I don't know what the memoryoverride.reg file is, but it's not the one I linked to, and probably not the fix to the problem your having.
Offline kolias
  •  1,165 1,165
Re: Posting gCode
« Reply #12 on: March 15, 2011, 06:39:24 PM »
Gerry you are a life saver.............
I first installed the “memoryoverride.reg” rebooted and did nothing
Then I installed LC alone (not from within Mach) and that did nothing
Then I installed the file from the link you provided and that did the trick. Not that it was so important but makes life much easier
Thank you both for your time
BTW the "memoryoverride.reg" is from the ArtSoft download section and I think is for people who have problems with Mack under Vista
Nicolas
