Hello Guest it is September 15, 2026, 07:33:36 AM
Author Topic: How to make Mach 3 to stop after every G-code line?  (Read 11603 times)
« on: March 12, 2011, 12:41:26 PM »
Hello I shall do a stop motion animation and I will use Mach 3 to move the camera to the right position for every single shot with the camera. Therefore I will do a G-code with the correct cordinates for the camera for every shot and the question is can I make mach 3 to stop after every G-code line so it just move the camera a tiny bit and continue to the next position when I press a button on the keyboard or so?
Thanks for helping me!
Re: How to make Mach 3 to stop after every G-code line?
« Reply #1 on: March 12, 2011, 12:48:56 PM »
Sure.
Turn on Single Block and the code will run one line for each Cycle Start button press.
Russ
« Reply #2 on: March 12, 2011, 12:49:40 PM »
Use Single Block button and it will do one line and wait for you to press start. If thats noot what you want can you explain more?
« Reply #3 on: March 13, 2011, 04:02:38 AM »
Ok, yes that was what I searched for, thx
