Hello Guest it is November 24, 2026, 08:10:55 AM
Author Topic: Mach 3 Configuration  (Read 10536 times)
« on: March 09, 2011, 10:02:17 AM »
Hello all,
I am a total newcomer to CNC.  I have installed Mach3 on my Vanguard 7000 machine and my re-set button will not activate, in that I get a message - "External E-Stop Requested"
Can someone here please direct me down the right road to correction?
Witelite
Re: Mach 3 Configuration
« Reply #1 on: March 09, 2011, 10:14:14 AM »
If you have an E-Stop button on the machine then it is likely you have the wrong pin or port assigned for it, if you dont have a real button, you really should ;) but go to Config menu then Ports and Pins then Inputs. Scroll down to E-Stop and change it to active Low.
« Reply #2 on: March 09, 2011, 11:42:44 AM »
Thank you so much!
