Hello Guest it is November 01, 2026, 10:10:40 AM
Author Topic: cutting depth  (Read 8409 times)
cutting depth
« on: March 07, 2011, 07:57:26 PM »
When I set depth to cut in Lazycam it is not the same when I post it to Mach.
Re: cutting depth
« Reply #1 on: March 08, 2011, 04:49:13 AM »
Ed,
Post the LCAM file and the generated gcode. Believe you are doing something wrong in LC . Make sure that the scale for the axis in Mach is set to 1.
Are you using the mill module? What version of LC are you using? There is a manual for LC in Members Doc's....i assume that you have read it.
