Hello Guest it is November 12, 2026, 10:59:41 PM
Author Topic: running in metric  (Read 10165 times)
running in metric
« on: March 07, 2011, 11:50:29 AM »
Mach 3 runs in imperial out of the box.
is there a check list of what i need to do to run in metric.
I'm plasma cutting with rack & pinion and a 5mm pitch ball screw for z.
I have it  running nicely in imperial but would like a metric profile as well.
I know i'll have g20 or g21.
AL
UK
Re: running in metric
« Reply #1 on: March 07, 2011, 01:06:16 PM »
First thing is Config menu Then Set Native Units, choose metric. Next is work out your steps per unit for each axis, in the case of metric a unit is 1mm, lastly will be getting your velocity and acceleration, if steppers that will be trial and error if servos the Vel will be known, acceleration will be by trial and error. As you already have an imperial profile multiplying the Vel and Accel by 25.4 should work fine.
« Reply #2 on: March 07, 2011, 01:52:53 PM »
Thanks thats just want i wanted.
Carnoustie, what a great place to play golf.
« Reply #3 on: March 07, 2011, 01:56:08 PM »
LOL, well I suppose it is, just have not had  time for it since I was about 12 ;D
