Hello Guest it is October 23, 2026, 04:05:42 AM
Author Topic: Troubleshooting Limits  (Read 98821 times)
Re: Troubleshooting Limits
« Reply #60 on: March 08, 2011, 05:55:20 PM »
Sorry second screenshot is wrong, I forgot to change the active state on the Z Home, so second screenshot should not have the M3 Home lit.
Offline kolias
  •  1,165 1,165
« Reply #61 on: March 08, 2011, 05:57:22 PM »
That is correct Hood,
Thank you all
Nicolas
Offline Sage
  •  370 370
« Reply #62 on: March 08, 2011, 05:59:09 PM »
It seems to me you have indicated that A is on all the time. Is there still a problem there?
What is A for you anyway?
It's a rotory table for me. What do you do with it?
Sage
« Reply #63 on: March 08, 2011, 06:00:23 PM »
Offline Sage
  •  370 370
« Reply #64 on: March 08, 2011, 06:03:41 PM »
Ahhh - forget my last post . If it works leave it alone I always say.  8)
Sage
Offline kolias
  •  1,165 1,165
« Reply #65 on: March 08, 2011, 06:05:26 PM »
Sage
Sorry Sage I thought I did reply
No, A is not all the time
A is my second motor on the Y axis. The gantry is driven by two motors, one per side (Y motor on one side, A motor on the other side)
Nicolas
Offline Sage
  •  370 370
« Reply #66 on: March 08, 2011, 06:07:27 PM »
So everything is good then?
Now go an cut wood.
 ;D
Sage
Offline kolias
  •  1,165 1,165
« Reply #67 on: March 09, 2011, 06:12:27 AM »
This is just the stock standard Mach screen, all I changed is the labels seen in the other post.
Put it in your Mach3 folder.
Open Mach, go to View/Load Screens and find it, then load it.
It has a different name so you can always go back to your original if necessary.
Good luck,
Russ
I would love to change my labels on the diagnostic screen like you did Russ in your previous post. I find mine (M1, M2 etc.) confusing
When I go to my View / Load Screens, there is only a 1024.set file available which brings the same screen I have on Mach
When you get some time, pls let me know in more details how you changed the labels
Nicolas
« Reply #68 on: March 09, 2011, 06:18:11 AM »
Download the screenset Russ attached and place it in the main Mach 3 folder. Open Mach then View menu then Load screens and choose the 1024Modified.set
Offline kolias
  •  1,165 1,165
« Reply #69 on: March 09, 2011, 06:28:00 AM »
I didn't see the file Russ attached on post 53
Now I just did it AND LIFE WILL BE LESS CONFUSING
Hood you are a life saver, thanks
Nicolas
