Hello Guest it is November 01, 2026, 10:10:38 AM
Author Topic: LazyCam double tracing?  (Read 13067 times)
« on: March 07, 2011, 02:22:01 AM »
Hi, I have found that with a few dxf's I make in Sketchup, LazyCam seems to generate gcode that retraces the same part twice, but at a very slight offset. It only does it for some parts, however i'm not quite sure what could be causing it.
Cheers,
Re: LazyCam double tracing?
« Reply #1 on: March 07, 2011, 04:34:32 AM »
Dan,
Post the dxf and will I take a look at it. I don't kow what Sketchup provides in a dxf and sounds like there are more than one lines. If the additional line was exactly like the other one checking the box to remove redundant lines  would remove it on import. After importing the dxf you may want to zoom way in and delete the offset line.
Is there a line width setting in Sketch up ? There are other free Cad programs out there and you may want to consider  one of them instead of SketchUp.
« Reply #2 on: March 07, 2011, 04:44:36 AM »
Here is the dxf: http://dl.dropbox.com/u/203420/Lightning.dxf
It seems that pretty much everything but the main outer rectangle is traced twice?
Cheers,
« Reply #3 on: March 07, 2011, 04:55:36 AM »
The main outer rectangle is also traced twice. In LazyCam
SETUP>LOADING OPTIONS> "check the box" REMOVE DUPLICATED LINES
That will remove them.
« Reply #4 on: March 07, 2011, 05:06:22 AM »
Interesting, not sure how they get duplicated in the first place, but thanks for the help!
Cheers,
« Reply #5 on: March 07, 2011, 05:29:24 AM »
That's for you to find out. :)
