Hello
Guest
it is
November 04, 2026, 04:03:35 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
General CNC Chat
Share Your GCode
Dragon GCode
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: Dragon GCode (Read 72886 times)
mikee
100
Re: Dragon GCode
Reply #10 on:
July 24, 2011, 09:38:13 PM »
hey Graham
i did what you said at first it was doing
then my cnc kept going _x _x untill it hit my limits about 250mm -x
mike
mikee
100
Re: Dragon GCode
Reply #11 on:
July 24, 2011, 09:50:37 PM »
hey graham it was like i changed the off sets in the middle of the file
i have rewind several times to set z plunge bepth at the first of the file i did the by zero my z axis dro not by changing g codes .
mike
BR549
6,965
Re: Dragon GCode
Reply #12 on:
July 24, 2011, 09:56:08 PM »
THere IS a problem with scale. It sometimes changes in the middle of the program run.
Just a thought, (;-)TP
mikee
100
Re: Dragon GCode
Reply #13 on:
July 24, 2011, 09:58:21 PM »
I am glade i i put 2x 8 ft sheet of mdf and said im just going to practise on this half sheet
until it is all cut to pieces . because it is starting to look like junk.
mikee
mikee
100
Re: Dragon GCode
Reply #14 on:
July 24, 2011, 10:00:37 PM »
not very good on g codes yet what would i be looking for and can i fix this
mikee
100
Re: Dragon GCode
Reply #15 on:
July 24, 2011, 10:04:00 PM »
i have not change anything on my cnc beside raised z axis
mikee
100
Re: Dragon GCode
Reply #16 on:
July 24, 2011, 10:05:35 PM »
scale on program run is the same as when i set it
mikee
100
Re: Dragon GCode
Reply #17 on:
July 24, 2011, 10:06:38 PM »
scale 0.9000 same as when i set it
mikee
100
Re: Dragon GCode
Reply #18 on:
July 24, 2011, 10:12:28 PM »
started to read lines g code the x is to the minus side every line 2 to 4every line mike
mikee
100
Re: Dragon GCode
Reply #19 on:
July 24, 2011, 10:13:32 PM »
sorry 2 to 4 mm every line toward _ x axis
Print
Pages:
1
2
3
Go Up
« previous
next »
