Hello Guest it is November 04, 2026, 03:00:32 AM
Author Topic: Dragon GCode  (Read 72871 times)
andrewm
Dragon GCode
« on: March 04, 2011, 09:28:59 AM »
Anyone have GCode or DXF for something similar to my attached image? Or if at all possible willing to turn this into a Gcode/DXF?
« Last Edit: March 04, 2011, 09:32:18 AM by AndrewM »
Re: Dragon GCode
« Reply #1 on: March 04, 2011, 10:19:29 AM »
Hi
Are you looking to engrave this  and what size are you looking for
andrewm
Re: Dragon GCode
« Reply #2 on: March 04, 2011, 10:53:13 AM »
Afternoon
I'm actually looking to cut it out on a plasma cutter with a 24inch Diameter roughly
Re: Dragon GCode
« Reply #3 on: March 04, 2011, 01:11:03 PM »
Hi here is an NC file to cut this image some detail is missing due to the original image size and properly the software i used to convert to DXF
andrewm
Re: Dragon GCode
« Reply #4 on: March 07, 2011, 09:00:06 AM »
Thanks!
Offline Arbo
  •  50 50
Re: Dragon GCode
« Reply #5 on: March 26, 2011, 05:44:36 AM »
Nice, Steve, can you put up the dxf so it can be used to do a vcarving?
Re: Dragon GCode
« Reply #6 on: March 26, 2011, 08:27:22 AM »
CNCSteve = What software are you using for the conversion?
Offline mikee
  •  100 100
Re: Dragon GCode
« Reply #7 on: July 24, 2011, 02:30:22 AM »
 hi  Andrew
 i think your dragon is way cool  i am new to this .
 the down load of the dragon gives x 630.8750 then y axis is 611.2970 if did my math right mm to standard y axis is just over 24 in.
i have a diy cnc router x74.5 y 23.5in 611.2970 mm is hitting limit SW  y + i tried to look this up in the manual and i remember resizeing or scalling somthing like that except i cant find what im looking for to reduce the size of your dragon by 10 % im  a newbie  i am not sure if i am  useing the right word i really want to make your dragon but more important to me to learn how to make my own stuff i dont care what example i work on i just need to know figure this out. is resizeing the right word   was going to run dragon file with z axis -0.030 in mdf see how it looks
Can you get me going in the right direction i have been studying gcodes and m codes  is plain to see i havent study enough
thank you muke
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Dragon GCode
« Reply #8 on: July 24, 2011, 03:45:07 PM »
On the main screen you have scale entries next to the position dro,s click one of them and enter 0.9 and hit enter do this on both X & Y axis.
Graham
Offline mikee
  •  100 100
Re: Dragon GCode
« Reply #9 on: July 24, 2011, 07:51:49 PM »
thank you so much  Graham i will try this.
mikee
