Hello Guest it is November 13, 2026, 12:31:59 PM
Author Topic: XML restore  (Read 13281 times)
XML restore
« on: March 02, 2011, 11:55:45 AM »
Hi Guy's
I have updated my version of Mach and it lost the setting's i have a back up and there are saved back UP's of Mach in the back up file folder question is how do i restore the XML a simple copy and paste dose not work any and all help is always greatly appreciated.
Dennis
Re: XML restore
« Reply #1 on: March 02, 2011, 02:02:13 PM »
Simply pasting the xml back will do it, why it doesnt for you I am not sure. Only thing I can think of is you are not pasting a xml of the same name or not starting the xml you have loaded. The other thing I can think of is you are placing a backup rather than a xml.
As to your other part of your question, if you go to I think Operator menu you will see a restore option, you can then choose out of the list which backup to install.
Re: XML restore
« Reply #2 on: March 02, 2011, 02:22:11 PM »
Thanks Hood
One more question i have is in my G-code i have the feed at 400 MM but when the G-code is run on the machine the feed rate is 290 MM not 400 i have to over ride the feed up to 560 before i get the feed rate i wish to have the machine operate at.
Re: XML restore
« Reply #3 on: March 02, 2011, 02:28:51 PM »
Can you attach your xml and some code please.
Re: XML restore
« Reply #4 on: March 02, 2011, 05:46:16 PM »
Hi Hood
Problem is all the code and XML are on a stand alone system no internet connection i have to copy it all to a drive and then to the internet computer.
Dennis
Re: XML restore
« Reply #5 on: May 31, 2015, 05:40:57 AM »
Hello freinds;
i want to know how i can make a general back up of my Mach3.
i need to reinstall my mach3 due to a problem in the regen. toolpath function.
the most imprtant for me is the Macros , Subroutines , Pin I/O config. Motors... and Plug ins.
how to restore again??
regards;
Ghantos
