Hello Guest it is November 12, 2026, 02:35:35 PM
Author Topic: Max Servo speed  (Read 11386 times)
Max Servo speed
« on: March 01, 2011, 02:17:31 PM »
Is it possible for SS to drive a servo motor at a speed greater than the nameplate RPM, without raising the voltage?
Ozzie
Re: Max Servo speed
« Reply #1 on: March 01, 2011, 05:03:24 PM »
A servos rpm is proportional to voltage. I don't think the motor would last long, if you provided more voltage than it's rated for. I've read that you really should design to run at 80% of the rated rpm.
The Smoothstepper just sends step and dir signals, and can only have it go as fast as you have your motor tuning set.
