Hello Guest it is November 10, 2026, 04:35:46 AM
Author Topic: Denford Micromill convert to Mach  (Read 31252 times)
Re: Denford Micromill convert to Mach
« Reply #10 on: February 27, 2012, 11:15:54 AM »
Angel Tech - would you be able to provide some advise on component selection?
Yes just give me a ring, pm'ed the details.
Offline Rex B
  •  12 12
« Reply #11 on: June 12, 2014, 07:57:34 AM »
I know this is an old thread, but I have the same situation - Perfectly good Denford Micromill 2000 lacking software, wanting to run it on Mach3.
The above advice is to replace the steppers, or the main board. Why is this?  Is the driver board specific to the software?
Angel Tech says I can just replace the control board, which I assume is the largest board, called "Denstep", and wire a new board to the other components.     I happen to have a CNC2PC breakout board.  It is a C11 Rev 5.
Will this work?
« Reply #12 on: June 12, 2014, 10:22:23 AM »
Hi Rex, I converted my MicroMill to Mach3 with a cheap B.O.B and 3 R/C servo connectors.  The Denford top board (with the little L.E.D. display) is removed & discarded.  The 96 pin header on the main board is where you connect to the appropriate step, dir & gnd pins with wires from the B.O.B.  Here's a link to a post over on the Denford forum that got me going.  http://www.denfordata.com/bb/viewtopic.php?f=54&t=2264
Milton from Tennessee ya'll.
