Hello Guest it is November 22, 2026, 02:29:05 PM
Author Topic: Need Help A-axis.  (Read 8991 times)
Need Help A-axis.
« on: February 24, 2011, 08:10:24 AM »
Hello all,
I am new to this forum and need some help in setting up the A-axis for driving a tool turret on my Emco5cnc lathe.
The turret has a new stepper motor and an optical 1 slot detector.
The turret will turn if I give out the G-code ; g00 a60 .
It should go 60 degrees, sometimes it does this and most times not it will turn forever.
The zero slot lights up in A-home in the diag screen.
What does Mach3 do with the A-home light?
I want to use a code or macro so that the turret turns around to the zero pulse output by the optical slot.
Then turn as many degrees as needed by the tool # input. I.E. 3 = 180 degrees.
The turret is a 6 position, the stepper needs to go forward to the position indicated and reverse back a little to the stop pawl.
Any advice is very welcome.
Jos Raven
Holland
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Need Help A-axis.
« Reply #1 on: February 26, 2011, 06:29:36 AM »
Hi Jos,
do a search on here for 'tool change macro' or something similar, you will find many versions but there is one on here for the emco.
I may be this one:-  http://www.machsupport.com/forum/index.php/topic,16685.0.html
Graham
« Reply #2 on: February 26, 2011, 08:37:05 AM »
Yes Graham,
I was aware of that one, tried it but I only get syntax errors in VB Sript.
Thank you,
Jos
Hi Jos,
Graham
