Hello Guest it is October 21, 2026, 02:40:25 AM
Author Topic: Aluminum Bearing Block  (Read 14601 times)
Offline kolias
  •  1,165 1,165
« on: February 23, 2011, 06:56:44 AM »
The attached picture represents a bearing block made out from an aluminum flat bar 1” thick by 2”x 3” with four 1/4" mounting holes and one hole 1-1/16” in the center for the bearing.
My question here is that I see these red lines (are they called Rapids ?) appearing to be much higher than the aluminum piece.
Am I doing something wrong or it supposed to be like that?
Nicolas
  •  9,374 9,374
Re: Aluminum Bearing Block
« Reply #1 on: February 23, 2011, 07:31:27 AM »
Nicolas,
They will be related to your 'safe Z' setting either within Mach or the software you used to create the part.
« Reply #2 on: February 23, 2011, 08:31:11 AM »
Correct me if I'm wrong (don't have Mach3 installed here), but the SafeZ setting in Mach3 has nothing to do with the rapid height.
Rapid height is controlled by your CAM software.
  •  9,374 9,374
« Reply #3 on: February 23, 2011, 09:44:34 AM »
Gerry is right  :'(
Offline kolias
  •  1,165 1,165
« Reply #4 on: February 23, 2011, 10:45:34 AM »
So the rapids height is wrong as indicated?
Nicolas
  •  9,374 9,374
« Reply #5 on: February 23, 2011, 10:53:49 AM »
No, not wrong, just more travel than you perhaps really need.
« Reply #6 on: February 23, 2011, 04:48:31 PM »
I don't know what program you are using, but for LC, see see Tutorial #6 in the manual.
Offline kolias
  •  1,165 1,165
« Reply #7 on: February 23, 2011, 07:18:30 PM »
Thanks RICH I was already there and now I can see that these red lines are the Rapid Heights. Since this subjects involves LC and I have more questions, I will start another post in the LC section of the forum.
I want to start some cutting with LC to familiarize myself with the techniques and then I plan to purchase a more dedicated CAM software
Nicolas
