Hello
Guest
it is
November 13, 2026, 10:36:17 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Lazycam Directions?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Lazycam Directions? (Read 10672 times)
jporter
15
Lazycam Directions?
on:
November 20, 2006, 01:38:59 AM »
What controls whether lazycam moves clockwise or counterclockwise on segment? Is there a way to set the default to clockwise or counterclockwise?
-Jason
Logged
jporter
15
Re: Lazycam Directions?
Reply #1 on:
November 20, 2006, 12:27:18 PM »
OK, so the segment cut direction is determined by the "Climb Mill" check box when you select the segment lead in. Is there anyway to set the default to a NON Climb Mill?
Jason
Logged
Brian Barker
3,860
Reply #2 on:
November 20, 2006, 04:57:14 PM »
Not at this time but We will look into it for a load option
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
