Hello Guest it is October 31, 2026, 01:13:26 PM
Author Topic: Mach 3 toolchange for dummies???  (Read 246177 times)
Offline rasta
  •  32 32
Re: Mach 3 toolchange for dummies???
« Reply #160 on: October 29, 2013, 03:59:24 AM »
Hi Hood;
Can you please suggest a line that can be added to the vb script so the program does not start until the signal is given that the Toolchanger has reached the bottom of the location slot? That way if there is any missing steps in the Toolchanger stepper it will not do anything until corrected
Kind regards
Mariano
After some sleep I see you wouldnt actually have to put the move to toolchange pos in each section, just having Code "G53 G0 X* Z*" after the first block would work fine.
Like this
 If GetSelectedTool() = GetCurrentTool() Then
End
 End If
Code "G53 G0 X* Z*"
While IsMoving()
Wend
 If GetSelectedTool = 1 Then
 ActivateSignal(OutPut2)
 Sleep 500
 Code "G53 G0 A0"
 While IsMoving()
 Wend
 DeActivateSignal(OutPut2)
 End If
 If GetSelectedTool = 2 Then
 Sleep 500
 Code "G53 G0 A45"
 While IsMoving()
 Wend
 End If
« Reply #161 on: October 29, 2013, 02:12:00 PM »
Do you have an input to Mach that shows the turret is not clamped?
Offline rasta
  •  32 32
« Reply #162 on: October 29, 2013, 02:21:46 PM »
i have set up pin 11 as an input , and fitted a limit switch inside the toolchanger that closes when the toolchanger shaft has bottomed, but, Im lost on the VB bit
« Reply #163 on: October 29, 2013, 02:37:58 PM »
Maybe something like this would do.
 Sleep 500
 Code "G53 G0 A0"
 While IsMoving()
 Wend
sleep 1000
If IsActive(Input*) Then
End
Else
MsgBox("Turret not clamped")
DoOemButton(1003)
End If
 End If
Offline rasta
  •  32 32
« Reply #164 on: October 29, 2013, 02:47:43 PM »
Tank you Hood;
I will try it tonight when I come back, now I have to drive a Mori-Seiki, with twin chucks and live tooling .great machine.
regards
Mariano
 Sleep 500
 Code "G53 G0 A0"
 While IsMoving()
 Wend
sleep 1000
End
Else
DoOemButton(1003)
End If
 End If
« Reply #165 on: October 29, 2013, 04:06:36 PM »
Thinking about it you will likely get away with just putting these lines at the end of the macro rather than having to put them in each tool call.
Offline Tr_G
  •  10 10
« Reply #166 on: October 29, 2013, 07:47:38 PM »
I did get the tool changer working on a 1984 Kitamura but only in clockwise direction. When I tried to go cw and ccw it would miss count the tool because when the motor on the changer stopped sometimes the led signal will be on and sometimes off and this would mess up the tool count.
If any one can add some code to correct the position to check if the led signal is on when it finishes the tool change rotation this would correct the cw cww problem.
'Find shortest route to next tool
ChgTool = (NewTool - SpinTool)
If ChgTool < 0 Then
   ChgTool = (16 + ChgTool)
End If
If ChgTool > 0 And ChgTool <= 16 Then          'in my code here I changed the 8 to 16 so it only goes CW
   Call CW(ChgTool)
   Exit Sub
End If
If ChgTool > 0 And ChgTool > 8 Then
   ChgTool = (-16 + ChgTool) * -1
   Call CCW(ChgTool)
   Exit Sub
End If
« Last Edit: October 29, 2013, 07:53:22 PM by Tr_G »
