Hello Guest it is November 24, 2026, 03:26:04 PM
Author Topic: Change options for combined jog axis  (Read 21664 times)
« on: February 18, 2011, 09:20:24 AM »
In machscreen I have axis choices that say
Jog X and A axis together (foam machines)
Jog Y and A axis together (foam machines)
The second choice should refer the Y and B axis
I believe this was intended to drive a 4 axis foam machine cutter to jog in a 2 axis functionality.
This would be awesome but the axis ref needs to change.
This is great control software - Thanks
Re: Change options for combined jog axis
« Reply #1 on: February 28, 2011, 06:44:20 PM »
I'm not really good with VB programming but maybe you could use something like swap axis.
Look at page 98 of the VB programming in the attached PDF
« Reply #2 on: March 01, 2011, 07:50:41 AM »
I guess I could try and make a work around for this.  On page 120 of the document you linked me to - it actually has the correct axis referenced.  Codes 354 & 355 say they should ref Y-B ++ and Y-B--, unfortunately in mach - the codes actually move Y-A++ and Y-A--.  This looks like it was intended to be implemented correctly but was inputed as a "typo"
« Last Edit: March 01, 2011, 07:54:00 AM by 1000ipm »
