Hello Guest it is November 13, 2026, 05:12:13 PM
Author Topic: pokeys switch and led  (Read 12533 times)
« on: February 15, 2011, 06:52:59 PM »
hi guys
i've just bought a pokeys55t for different purpose than your guys. i'm starting to build a small cockpit to play around flight simulator fsx. i want it to know inf anyone could  explain me how do i make a switch turn on a led light with pokeys? i know that this could be a stupid question for you guys but the fact is that i'm a newbie in this electronic stuff and any help or advice you can give mei would aprecciate it. sorry for bad english.
best regards
Offline borisz
  •  220 220
    • www.poscope.com
Re: pokeys switch and led
« Reply #1 on: February 15, 2011, 10:09:32 PM »
Hi!
Use resistor 330 to 670 ohm and connect it inseries with LED.
After that with PK vonfiguration software configure that pin as output. You can switch on and off in PoKeys configuration software.
Also you have some examples and descriprion in user manual and on www.poscope.com how to do these with your own software.
