Hello Guest it is November 04, 2026, 01:04:07 AM
Author Topic: Tool offsets and long delays vs Work offsets - help  (Read 56082 times)
Offline rcaffin
  •  1,073 1,073
Re: Tool offsets and long delays vs Work offsets - help
« Reply #10 on: February 14, 2011, 06:10:25 PM »
The tools3.dat, renamed as TXT because I can't upload DAT files here.
« Reply #11 on: February 14, 2011, 06:41:41 PM »
Well afraid I cant seem to load your code, get a too many nests error. Looked at it and its way beyond my knowledge of code ;)
However I loaded your xml and tooltable and ran some of my code and it ran fine, spindle only stopping when commanded and not at tool changes so I am guessing that its your code that is doing the stopping.
« Reply #12 on: February 14, 2011, 06:47:27 PM »
Oh BTW if you are threading you really want to have Use Spindle Feedback in Sync Mode chosen.
Offline rcaffin
  •  1,073 1,073
« Reply #13 on: February 14, 2011, 06:50:54 PM »
Now that is WEIRD! All my code looks like that and loads and runs just fine.
OK, I have about 40+ years experience programming computers at all levels, so I tend to think that way. Mind-set!
I have attached a very simple version of that program with just one subroutine call. Could you try it maybe?
Spindle mode for threading - yes, I do that on the 'real' machine. The XML is from my simulation machine.
Roger
« Reply #14 on: February 14, 2011, 06:54:01 PM »
Ok get return called with no sub in effect looping error with that one.
Offline rcaffin
  •  1,073 1,073
« Reply #15 on: February 14, 2011, 07:16:08 PM »
Damn!
Rule 1 of SW: there is always one more bug in the code than you think. That was a hacked down version of the original of course, and there was a superfluous m99 in it.
The attached has been fixed and tested.
I am wondering whether the real problem is the M3 instruction after the tool change. That basically says to start spinning, and should be a no-op if the spindle is running. I need to look at the macro  to see just what it does.
« Reply #16 on: February 15, 2011, 01:19:57 AM »
Sorry had to sleep ;D
Just tested with your xml and the only time the spindle switches off is at the end so looks like your M3 macro could well be the issue.
Offline rcaffin
  •  1,073 1,073
« Reply #17 on: February 15, 2011, 02:54:59 AM »
Nice thought, and I wish it was so. But all that is in M3.m1s is:  DoSpinCW()
If I leave the M3 call out, the spindle still stops when it gets a Tn0n command. It just doesn't start again.
So I have to say I think it is the T command which is doing the stopping - even when AutoChanger is selected.
Is there some other switch in the XML or elsewhere I wonder?
V3.042.040
« Reply #18 on: February 15, 2011, 05:15:01 AM »
I am testing with the latest lockdown but will go load the older version you have just in case that makes a difference but definitely no spindle stop here at tool change. The only other thing that is different is I am using a different screenset as I dont have the one you have loaded, so may be worth trying the standard screenset.
Only other things I can think of that could affect things is if you have a plugin or brain or macropump that is interacting. You dont have macropump enabled in the xml but not sure about the others.
« Reply #19 on: February 15, 2011, 05:25:04 AM »
Just loaded 042.040 and its still fine, so look at screenset, brains and plugins to see if there is something there that could be the issue.
