Hello
Guest
it is
November 22, 2026, 08:25:20 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
calibrating
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: calibrating (Read 9662 times)
moxy
34
calibrating
on:
February 14, 2011, 01:50:49 PM »
Hello all, I am trying to calibrate my dividing head (rotary axis) and am having the following problem. I am using the set steps utility in the settings screen and when I set the amount of degrees I want the divhead to turn a weird thing happens. If I set 360 degrees no movement occurs. If I set 359 degrees it moves 1 degree in the opposite direction. The position is correct but the stupid thing took a shortcut! If I set 330 degrees it goes 30 degrees the other way. Am I doing something completely dumb or should I operate the thing via a mirror
(lol) Any ideas?
Les
ostie01
628
Re: calibrating
Reply #1 on:
February 14, 2011, 01:55:50 PM »
It will depend if it is set in incremental or absolute mode
Also check in general config for the check box with Rot 360 rollover and ang short Rot on G0
Just play with setting
Jeff
moxy
34
Re: calibrating
Reply #2 on:
February 14, 2011, 02:03:19 PM »
Many thanks Jeff, I will give it a try.
best regards
Les
Print
Pages:
1
Go Up
« previous
next »
