Hello Guest it is November 01, 2026, 11:56:37 AM
Author Topic: LCAM Ver 2.66 has new layout and I'm confused...  (Read 9586 times)
« on: November 18, 2006, 04:10:44 PM »
It seems that my "layer Control" button at the top has been replaced with 'Autoclean Settings'.  I like the new Autoclean settings button but, I kinda miss my layer control.  Is it gone forever?  If so, how can I prevent a layer from being cut but NOT delete it from the file?
Also, I accidentally closed the Layer/Object Properties box and couldn't get it to show again (I finally closed LCAM and re-opened and there it was but, is there a way to show and hide it without getting out of the program?
Sid
Re: LCAM Ver 2.66 has new layout and I'm confused...
« Reply #1 on: November 19, 2006, 10:12:10 AM »
The Layer dialog is GONE :) It was a pain in the butt! We will add a way to turn off a chain with a right click and that should help you
We need to take away the Your problem with turning off the properties box is on the list for fix and should be in the next week or so .
thanks
Brian
www.newfangledsolutions.com
www.machsupport.com
