Hello
Guest
it is
October 20, 2026, 03:00:46 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Denford Orac 8 station turret
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
8
9
Go Down
Author
Topic: Denford Orac 8 station turret (Read 118598 times)
angel tech
499
Re: Denford Orac 8 station turret
Reply #60 on:
March 18, 2011, 04:20:15 PM »
take the toolplate off and there should be a cover, underneath it is the ratchet/pawl.
Logged
Carnoustie, Scotland
Reply #61 on:
March 18, 2011, 05:34:59 PM »
Sounds like you are nearly there
Logged
stefan
10
Reply #62 on:
March 19, 2011, 03:59:20 AM »
Hallo
Please help.
I built an auto rotary tool changer with a stepper motor. It doesn't have any solinoids. I use my B axis for my toolpost.
My only problem is that I don't know how to tell Mach 3 that this has to be my toolpost axis. I want it to be a 6 or 12 station tarret and I don't know how to configure my settings in Mach 3 to let my toolpost operate.
Please let me know or if you have settings for me?
stefanvonstade2@gmail.com
Logged
Reply #63 on:
March 19, 2011, 04:02:17 AM »
stefan
read through this thread and it should help you understand
http://www.machsupport.com/forum/index.php/topic,17567.0.html
Logged
stefan
10
Reply #64 on:
March 19, 2011, 04:45:42 AM »
thanks for quick reply, I will try it now.
I will come back to you with results
Logged
stefan
10
Reply #65 on:
March 19, 2011, 05:09:41 AM »
My general logic configuration screen is different from yours, it doesn't have Rot 360 rollover.
What must I do?
Logged
Reply #66 on:
March 19, 2011, 05:23:42 AM »
Because you have said General Logic rather than General Config I am thinking you must be using Mach2. You will really need to change to Mach3 I think.
Logged
berty
74
Reply #67 on:
March 19, 2011, 07:42:47 AM »
Hi Hood
Yes nearly there I am tidying wiring and trying to install it all in an old PC tower box.
I have also got to sort out stepper drives into tower as well
Then I will be able to test it out using coolant pump control
Looking forward to getting to next stage of configuring the tool positions
bert
Logged
stefan
10
Reply #68 on:
March 22, 2011, 05:59:49 AM »
The program settings you gave me was done in notepad format and saved on my C drive as well as underneath the folders Macros, Mach3 Turn. BUT it doesn't want to open when I'm in VScript.
How can I save these settings otherwise?
Please help
Logged
Reply #69 on:
March 22, 2011, 06:56:22 AM »
did you save it with a m1s extension?
Logged
Print
Pages:
1
2
3
4
5
6
7
8
9
Go Up
« previous
next »
