Hello Guest it is November 13, 2026, 08:05:12 PM
Author Topic: Help  (Read 10722 times)
Help
« on: February 09, 2011, 05:06:19 AM »
I have two PC`s one in the house and one in my workshop,
 house one is running W7 and is a AMDx2 4gig ram,
workshop one running XP Intel 3000, 4 GIG RAM,
 i have put a demo version on both machines and am using Vetric cut2d
 to create the drawings, the problem is my home PC displays all the code
 correctly no problems and simulates the cutting but my workshop PC
only some of the code and for instance if i have a word i only see on or two letters,
 plus i can not display more than one layer in a 3d cut, can any one help please :(
Re: Help
« Reply #1 on: February 09, 2011, 06:41:49 AM »
Demo is restricted to 500 lines of code, the difference however may be you have the driver installed on one so it shows the limit and the other doesnt have the driver installed so it allows the whole toolpath to show as.
Cant help with Cut3D I am afraid.
Re: Help
« Reply #2 on: February 09, 2011, 07:04:49 AM »
I can display one file of over 1000 lines no problem but some only 100?
Re: Help
« Reply #3 on: February 09, 2011, 07:46:56 AM »
Can you attach the xml from both machines and also the code that gives you problems.
