Hello Guest it is November 04, 2026, 03:23:18 AM
Author Topic: turning g code  (Read 15770 times)
turning g code
« on: February 07, 2011, 10:44:36 AM »
I am just getting started and I would like a G code for turning down rod to a predetermined O.D.
I would like the whole code so that I can see how the code works.   I am using a gear cutting wizard currently and I can make it do what I want but I can't see the whole code and this make thing harder to learn.
Any help would be greatly appreciated.
Thanks Jay
Re: turning g code
« Reply #1 on: February 07, 2011, 04:26:04 PM »
Jay,
Try using one of the lathe wizards. There is one for turning a rod  down to a diameter.
You can play alll you want and will learn by doing.
Re: turning g code
« Reply #2 on: February 07, 2011, 04:51:14 PM »
Rich,
When I was reviewing the Wizards this morning, they looked the same as my Mill Wizards.
I will check again when I get home!!
Thanks Jay
Re: turning g code
« Reply #3 on: February 07, 2011, 06:58:11 PM »
Jay,
I just assumed that you were talking about using the the lathe along with the lathe screen.
You will find lathe wizards but the mill wizards willl not be listed.  ???
