Hello Guest it is November 13, 2026, 08:00:47 PM
Author Topic: Screw whip help needed (8020 2x3 machine)  (Read 11261 times)
« on: February 06, 2011, 04:52:37 PM »
I have the FLA100 kit from
Store: FLA100-00 : Fine Line Automation
The x-axis seems to get some whipping with the screw rod. Not sure what I did wrong and how to stop it. I would appreciate any help on this problem.
Re: Screw whip help needed (8020 2x3 machine)
« Reply #1 on: February 06, 2011, 08:03:32 PM »
If it's whipping, the RPM is too fast.  Slow it down.  If your speed is not fast enough after slowing to where you get no whipping, you'll have to go to a courser screw pitch...or a screw with multiple starts.
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #2 on: February 07, 2011, 08:49:29 AM »
First check the screw by taking it out and rolling it across a flat table. If the screw flops around there it is a sign that it was not straightened after grinding. If the screw is not straight there is not much you can do to help except straighten it. Even with a relatively straight screw, if it is only supported on one end, you'll be limited to how fast you can turn it. Supporting the screw on both ends, under a bit of tension, will help keep it from whipping.
Happy machining , Jeff Birt
« Reply #3 on: February 07, 2011, 06:42:52 PM »
Thanks for the replies -
It is supported at both ends. If I hold my finger against the top of it while it turns, there is no flopping around. I will pull it off this weekend.
