Hello Guest it is November 13, 2026, 08:07:24 PM
Author Topic: E-Stop stuck on  (Read 8738 times)
E-Stop stuck on
« on: February 03, 2011, 09:11:40 PM »
HI, I'm having an issue with my E-stop. I can reset it (in the software) but it immediately comes back on. I have restarted my CPU, tried messing with the physical E-stop but to no avail. I'm new at this CNC thing so this is really slowing down my learning process since I cannot even get my machine to jog etc. while it is in the E-stop mode.
Any advice would be greatly appreciated.
Re: E-Stop stuck on
« Reply #1 on: February 04, 2011, 12:59:44 AM »
Sounds like you are getting electrical noise on the E-Stop signal, best to shield the wires properly if that is the problem but setting a debouce interval of 2000 might mask the issue until you can do that. You will find it from Config menu then General Config.
