Hello Guest it is November 13, 2026, 08:06:18 PM
Author Topic: Newbie Problem  (Read 10315 times)
Newbie Problem
« on: February 03, 2011, 05:31:18 PM »
Whenever I open Mach3, I end up with an error message that states " Initialization Macro called upon reset". What is it and how do I rectify the problem?
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: Newbie Problem
« Reply #1 on: February 03, 2011, 05:39:31 PM »
That is not an 'error', it is just informational. If you look in the general configuration window, you will see a section that controls what happens on initialization/start up (called Startup Modals). Generally it is a very good idea to have your control start up in a known state so if you try and jog you know what will happen (for example). The message is just letting you know that the initialization has been done.
Happy machining , Jeff Birt
Re: Newbie Problem
« Reply #2 on: February 03, 2011, 06:05:54 PM »
Thank you very much for your quick response.
