Hello Guest it is November 10, 2026, 01:55:27 AM
Author Topic: macro embedded in Gcode regens toolpath at 0,0  (Read 6165 times)
« on: January 31, 2011, 09:06:19 PM »
I recently created a VB wizard/macro that I intend to call from G-code.
I get the current X,Y, & Z location from GETOEMDRO().
I pass the necessary pattern information through P, Q, & R parameters.
In the g-Code, I position the tool at the macro starting location and then call the macro with the appropriate runtime parameters in P, Q, & R.
When I load the program, the macro's toolpath result is generated on the toolpath screen at current DRO location instead of where it is supposed to be. Because I call it several times in the g-code, all of the cutouts appear to be on top of each other (not pretty).
When I run the code, it appears to cut and display at the proper location (This is good).
Is this normal?  If not, what can I do to correct it?
Bill
Pixel Tamer
