Hello Guest it is November 10, 2026, 01:55:51 AM
Author Topic: Need someone to make wizard for spray cnc !!!  (Read 6139 times)
Offline GTR
  •  2 2
« on: January 30, 2011, 03:11:59 PM »
Hi
Need someone to make wizard for spray machine, it would be silly to make code for every single simple workpiece. Fair price and we have a deal !
Machine have a fixed z height and 2 position of spray gun on the moving head (up position=spraying the top of the piece, down position=at some angle for spraying the edge)
Moves will be with tangential control for proper orientation of spraying head for both the top and edge spraying.
When spraying  top of piece it must be done in X then in Y or vice verse  (wizard option).
Edge spraying should trigger some output pin to rotate head nozzle to proper position (down) and do move like cutout.
Wizard should have parameters:
X & Y dimension of workpiece
Corner radius
X,Y zero
X,Y stepover
Feedrate
Must have a options to select either to spray first edge then top then edge again or just top .... all sorts of combinations.
If someone can help, mail me at racing_gtr@yahoo.com or PM
