Hello Guest it is November 13, 2026, 04:57:59 PM
Author Topic: Driver watchdog triggered  (Read 34212 times)
Offline faby
  •  74 74
« on: November 16, 2006, 01:42:35 AM »
I was rotating the view of a 18Mb program when mach3 stops, turnig on reset button, and the "Driver watchdog triggered" appeared in the status bar.
the machine didn't working, was stopped (sorry for my english) I was just looking at the program.
What it means?
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Driver watchdog triggered
« Reply #1 on: November 16, 2006, 11:53:37 AM »
Hi, Faby
This happen's if you move the view around to much, I don't really now exactilly why, seem's like more than a 90 deg. rotation will do it.
Find a view you like, Reset Mach, a Regen tool path if needed.
Hope this Helps, Chip
« Reply #2 on: November 16, 2006, 12:03:54 PM »
Hi, I have found that this happens on computors that are under 1ghz. I guess windows is trying to update the screen and taking control away from Mach3 which Mach3 dosn't like too much.
I upgraded my processor from 733mhz to 1.3ghz and the problem disappeared.
Offline faby
  •  74 74
« Reply #3 on: November 16, 2006, 02:00:34 PM »
I use a P4 3GHz, 1Gb ram...
Well now I know that it's only a matter o view, I was scared that it could happen during the machine working.
That job need 12-14 hours of continuous work  :P
« Reply #4 on: November 16, 2006, 02:16:35 PM »
Hi, I see what you mean. Your computor speed seems fine. I have never had the error whilst the machine is working only when the screen was updating the new file I loaded.
« Reply #5 on: November 16, 2006, 06:53:18 PM »
Hi Faby,
you can disable the Driver Watchdog in General Config...
Greetings,
Wolfram
« Reply #6 on: November 17, 2006, 07:58:59 AM »
Yup, I turn it off because I have the Charge pump running :)
www.newfangledsolutions.com
www.machsupport.com
