Hello Guest it is November 23, 2026, 03:18:20 AM
Author Topic: Help For a Frozen Northerner...Mach3 Won't Talk  (Read 28284 times)
« on: November 15, 2006, 07:34:44 PM »
 I'm just finishing up (so I thought...) a bridgeport 3 axis mill conversion. I just soldered up the last of the connectors this morning and figured I'd be well on my way to making computerized metal chips. Or not.
 I have both the PC Motherboard Parallel port as well as a second PCI parallel port installed in a 1GHz Dell desktop. The only program loaded onto the machine is Mach 3. My controller consists of a power supply, (68 vdc), 3 Gecko G201's, and a cnc4pc.com parallel port breakout board. The motors are 8 wire steppers wired parallel. I have all my limit switches OP'd together on one input, and each home switch has its own pin. All switches used the method described in the Mach 3 mill book (5v, 470 ohm resistor, yada yada yada). I've tested my inputs (outputs from my mill to the computer) and they all trigger high (a tripped switch is sending a 4.75v signal). When I power up the controller, the steppers lock under power.
When I'm in the congif menus, I have tried both the motherboard parallel port, as well as the PCI board. Neither of them relay any signal back and forth. Messing around this evening, I got the PCI board to trip the "LED's" on the diagnostics screen which are in the form of the end of the DB25 connector. These leds are tripping when I trigger a limit switch or home switch. The LED's for the appropriate functions below the DB-25 LED cluster don't light up. I have noticed that with the machine and program sitting idle, a number of the LED's on the DB-25 cluster are lit up...without any inputs or outputs being requested (at least on purpose). I am admittedly way deep over my head on this one. I'm a mechanical engineer...this electrical stuff just makes me cranky:) I think I'm close, but there is obviously something in some setup menu that I have overlooked. There has been some discussion about the type of parallel ports which work with this system...I didn't know if that would have an effect on anything...??? Needless to say...the motors are not responding to any manual keyboard emulator jog inputs. Any help would be most appriciated.
Spencer Garrett
www.gpe-machine.com
« Last Edit: November 15, 2006, 07:36:34 PM by spencyg »
Re: Help For a Frozen Northerner...Mach3 Won't Talk
« Reply #1 on: November 15, 2006, 07:47:59 PM »
Hey Spencer,
    I have pretty much the same setup minus the second port. Where are you at? I think we can get you going.
« Reply #2 on: November 15, 2006, 08:16:10 PM »
Hampden, Maine....about half way up. Getting somebody who knows what in gods name is going on with that stupid machine would be a sanity-saver for sure. I have a feeling that there is something with my port config or something like that...actually...I have no idea.  ???
Spence
« Reply #3 on: November 15, 2006, 08:23:18 PM »
I have sent you an e-mail.
ynneb
« Reply #4 on: November 16, 2006, 12:58:06 AM »
If these videos dont get you up and going, then you best give me your electrical engineering papers :)
http://www.machsupport.com/videos.htm
Also the reading stuff here http://www.machsupport.com/documentation/M3M1_84-A2.pdf
Trust me, this stage will eventually be behind you and the chips will soon be flying.
« Reply #5 on: November 16, 2006, 05:26:54 AM »
 I found myself much closer last night after a phone discussion with Brett (thanks again!). My initial trials were with what I thought was a straight thru DB-25 cable. I think it actually wasn't straight through, because when I took a second cable (which was purchased from an electronics shop, and not a computer shop), everything started to wake up. I was able to get all limit and home switches to function. I also got the motors to do their thing, but only after disabling the limit switches. Without disabling the limits, I couldn't reset the Mach 3 e-stop...the message kept saying I had limits triggered, when I didn't. Any ideas on this one?
Spence
« Reply #6 on: November 16, 2006, 07:29:22 AM »
Hello Spence,
      You are welcome. I don't know for what though, you did it all yourself. Good job. ;) The only thing I know to do on that alarm is good old troubleshooting. Check your voltage and see that the switches are making and braking. Check to see that they are wired right and the active low, high is set up to work with your config. You may be able to narrow it down by disabling one switch at the time until the problem goes away. You will have to disable all of the limits you have wired to a single pin though. There is allways the possibility of it being a noise problem also. Have you ran the driver test? What is your debounce set at?
« Reply #7 on: November 16, 2006, 07:48:19 AM »
 I'll start knocking off possibilities one by one....its just a matter of time now. I'm not sure what the debounce setting is....what should it be? What does it do?
Spence
« Reply #8 on: November 16, 2006, 08:39:43 AM »
It helps confirm that an input is actually being seen. After the time you set your debounce to, mach will then acknowledge it. It helps remove flakey readings. Set it to 1000 and see if that helps any.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #9 on: November 16, 2006, 01:17:36 PM »
Hi, Spence
If your still not able to Reset machine and you have it wired up try changing the state, Active Low to opposite of what it,s set now.
Conf.-Port Pins Input's, scroll down to E-Stop, if that doesn't work set it to Emulated, then you can Reset, though your weired E-Stop won't work. Be Carefull now only Screen Reset , Stop will stop moves.
As far as your Limit's and Home switche's
In actuality you can use three switche's to control Home and Limit's with one Pin on your Par. port, if the Switche's are stationary to the axis that's moving with a tab that trigger's them at each end of travel.
If your using Two limit switche's at opposite end's of each axis and the home Switch's are located with one limit ( same Position ), you can use that limit switch for your Home switch also, Still just One Pin used.
If your using Normanly closed switche's they need to be wired in series, N - Open SW parallel
You can Emulate limit/home Switch's also, (some ver. of Mach you need to set the port to 0).
Hope this Helps, Chip
