Hello
Guest
it is
October 24, 2026, 12:01:37 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Slave Z to Y Axis??
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Slave Z to Y Axis?? (Read 11085 times)
fritts
2
Slave Z to Y Axis??
on:
January 26, 2011, 11:28:26 AM »
Is it possible to slave the Z axis to the Y axis? I have a 3 axis controller that I want to use to test a plasma cutter. Is it possible to reassign the pins or slave the Z axis to the Y axis to test the movement as I have 2 steppers on the Y axis and not enough axis on the Stepperworld board to control them.
Logged
Carnoustie, Scotland
Re: Slave Z to Y Axis??
Reply #1 on:
January 26, 2011, 01:20:35 PM »
Dont really follow what you are asking, if you are attempting to drive two motors from one drive then I cant say how successful that would be but Mach has nothing to do with it so no problems from the Mach end of things.
Logged
fritts
2
Reply #2 on:
January 26, 2011, 02:11:08 PM »
Since I don't have an A axis to slave for the 2 motors needed in the Y axis. Is it possible to slave the Z axis (which i'm not using) to the Y axis to run the addition motor needed on the Y axis. I'm not talking about driving 2 motors from the same axis. Just slaving the Z axis to the Y.
Logged
Reply #3 on:
January 26, 2011, 02:13:26 PM »
You just call the extra motor/axis the A and slave it to the Y.
Logged
kf2qd
157
Reply #4 on:
January 26, 2011, 03:37:01 PM »
If the both axis use the same drive setup you could tie them to the same outputs - if everything will cooperate electrically. The advantage of slaving it using A is that you can then do some things with limits and homing that you can't do the hardwired way.
Logged
Print
Pages:
1
Go Up
« previous
next »
