Hello Guest it is November 10, 2026, 01:57:46 AM
Author Topic: Need help with new macro or wizard  (Read 24929 times)
Re: Need help with new macro or wizard
« Reply #10 on: December 10, 2006, 05:02:52 PM »
That is okay to put them here.. I think at some point I can set up a place on the FTP server
www.newfangledsolutions.com
www.machsupport.com
Offline Scott
  •  140 140
« Reply #11 on: December 10, 2006, 10:08:54 PM »
Hi all,
I finally had some time to finish my "Hangslot Wizard".  There is a readme file included.  If you think it may be of some use to you, check it out.
Thanks to Brian and Graham for helping me out with my first wizard.  It's relatively simple, but it was a good learning experience.
I'm not the best mathematician so if you find something that doesn't add up, let me know.  ;)
« Last Edit: December 10, 2006, 11:05:08 PM by Scott »
Scott
Offline zarzul
  •  233 233
  • Wyoming, USA
« Reply #12 on: December 12, 2006, 09:44:22 AM »
Nice job on the wizard!
Keep up the good work,  need more wizards like this!!
Offline Greolt
  •  956 956
« Reply #13 on: November 03, 2007, 08:08:43 PM »
Scott
Believe it or not the little I know about this VB stuff as used in Mach I have learned from you.  So thanks for your efforts.
I had a poke around and converted it to metric.  Haven't used it yet.  Just a learning exercise.  ;D
Greg
Offline Scott
  •  140 140
« Reply #14 on: November 03, 2007, 11:44:17 PM »
 ;)  It was a learning exercise for me too.  Kind of fun though.  A good break from the day to day stuff.
I need to do it again.  With the control software I'm using now, I've set one up that is just dialog based and I'd like to make a "Virtual Tool" (wizard) that is has a GUI with drop down lists and fill in fields, but I haven't had the time to wade through Visual Basic to make one.
Scott
Scott
