Hello Guest it is November 17, 2026, 10:37:43 AM
Author Topic: home command gets interrupted  (Read 8710 times)
« on: January 21, 2011, 06:49:35 PM »
Hi Folks,
I have wired my home switchs and did not use a shielded, grounded cable as suggested. I used just single wires and they are intertwined with the motor wires in several places. When I press the "ref home" switch it takes several tries to get my mill table to the home position. The motors stop and I have to keep hitting the button.
My question: does this sound like interference on the home switches? I'm hoping it does and that my "lazy" wiring is the cause of that. Also were would you suggest I ground the shield?
-jim
Re: home command gets interrupted
« Reply #1 on: January 21, 2011, 07:19:48 PM »
Yes. try setting a high debounce interval on General Config page and see if that helps, try 2000.
Best though to sort your wiring out.
